- 23 فبراير 2009
Laptop repair industry simply Inside Story
Really notebook motherboard repair technician, have very strong chip circuit technology and rich experience of fault repair. Technology" is that everyone can learn, "experience" is at once in the accumulation of failure. Notebook motherboard repair technicians at the accumulation of experience in the process of repair will be inevitable "scrapped out" A lot of motherboards. 。 If the motherboard each calculated in accordance with the 1000, so far, I have been "scrapped out" more than 100 million motherboards (the actual absolute number of more than 1000).
Laptop repair course simply
。 In my opinion, outside the so-called notebook repair training courses, simply Do not want to bear the losses, many do not want to spend time training you can find out what kind of notebook motherboard repair technician?
Technology required repeated long-term accumulation of practical experience required
Take me, I train an apprentice in the factory are not fax capable, and most will show some superficial efforts. After all, my experience of these technologies and are exploring on their own out of step by step, to all of a sudden all the others, how I mix? Quite for me to spend money on training courses outside of those people are sad - not only but also will have learned nothing.
● notebook now grow light, grow thin, this is not a good thing
。 Book now grow light, grow thin, this is not a good thing. Doing light notebooks, thin to do, it means that the notebook motherboard has a small, thin done. Notebook motherboard is smaller, but above the chip and board layout will not change are small. In this way, the result of a "step-plate line of extreme-intensive" and "all kinds of chips from the compact," and so on.
Hand-off at my notebook motherboard, the thin-and-light the highest failure rate of the motherboard, the basic is "deformation motherboard" symptoms. "Motherboard deformation" will cause instability in notebook performance, there will be specific what kind of fault, really hard, but the results are positive repair - can not repair, we must replace the motherboard.
Thin and light notebook motherboard will be the more compact the higher density chips
Notebook motherboard has a small chip above the high intensity. ”。 Some small chips emit a very high heat, the heat will affect the surrounding "field effect transistor." "FET" generally used to control the creation or transformation of certain operating voltage, if it affected the main board will cause a short circuit. Once the motherboard short circuit, then on the big questions. It will add non-stop electricity, keep the boot, eventually burned down the processor and other components.
Therefore, the laptop's motherboard is not the smaller the better, as the heat will only increase the burden on the main board, main board increased the probability of a short circuit. ThinkPad X60s We know, ThinkPad X60s is the best brand of small-size models. It uses the Intel Ultra Low Voltage processor, and strictly control the internal operating temperature, greatly reduces the possibility of failure - that is, "Why ultra-low-frequency low-voltage processor, but a higher selling price," the reasons for the 1. Of course, this is only my opinion a rather piecemeal, and now the notebook manufacturing process with each passing day, "balance between security and thin" is not inconceivable.
