WINHEX WD ROYL series with ROM
ROM for WD ROYL series with use WINHEX
1: Tools PC3000 software
2: First of all find a same series of circuit board version number to the same disk is 701 444, and then brush similar to a failed drive rom
3: Look here, suggesting that the wrong version of ROM and SA
Configuration reading ...................: No SA copy avalabled
SA, the Firmware version ...............: Module part reading error - Device Error Detected: "Unknown error. The Error co-
4: into the PC3000 read out the failed disk module and track
5: winhex to open a same series of similar firmware good disk ROM and 102-109 module to analyze the relationship between the ROM module and SA modules
6: First contrast 102-0A 103-47 104-0d 105-30 107-0b 109-rom this is the correspondence between
7: Here we open the difference between the failed disk module 109 and the good-ROM disk to see if they
8: ROM file from 5A 04 00 00 91 0B 00 00 0A this module the last line of FF end of the address of the end, we find the fault plate 109 module to address in this section of the content found from 00,000,512 here to 00,197,104 end , we copy a section of content, built into the new file
9: and then contrast these two ROM copied from the module instead of the same place, we see that 0A 0B of content is similar to 30 modules in the fault disk not found in the SA module find 30 content 30 corresponding to the module 105, the first optimistic about the ROM 30 the number of rows is 64 rows in module 105 to select the first 64 lines of the first put the module in the 0501 logo changed to 300 030 doing a good job, and then look up There are 47 modules, corresponding to
47 module 103, open 103 also modify the module mark 0301 to 4700 the number of rows is 103, line 64, the entire file, 47 with the above will be equipped with two ROM 0D is the same, not with the following good ROM file and ROM module renamed BIN end of file
10: changing for the better written to the failed disk board ROM and ROM modules to be written, otherwise it will ROM coded
11: power the power to view has to realize that the model data complete with ROM successfully OK
Fire_Line
HawasTECH - Muhammad Hawas
5 سبتمبر 2009
رد: WINHEX WD ROYL series with ROM
Very Good Mr Mohamed We can say that "Generate ROM Manually" by analyze Modules of SA a good Donor and use win hex to make a rom.bin file
Modules :
SA module 105 = ROM 30 - Service Area translator
SA module 103 = ROM 47 - Service Area adaptives
SA module 102 = ROM 0A - head map
SA module 107 = ROM 0B - ROM module directory
SA module 104 = ROM 0D - firmware version
and 109
rom royl series wd winhex with
