ST for the repair Ways Bad Track
ST method for repair Bad Track
ST Bad Track for regular or abnormal sound is the head of the problem, we do not say here. Say only the first two hard disk is divided into two situations, a red and green points are very many overall. Bad Track one is not much, but not for the add.
The first solution, the overall red, green or red and green points, many of the disk, use the command to deal with. Thank required here "I was rookie," First of all methods required by the serial line (PC3K with this line, you can buy online). WINDOWS 98/XP/2000 into the system, enter the attachment / Communications / HyperTerminal
Into the process, with access to the serial line jumper at the hard disk spaces. Re-drawing power
CTRL+T。 CTRL + Z then the implementation of what the screen will be T /> Now enter the N31,, 22 re-implementation of CTRL + T. At this time for firmware self-test
If you need to pay attention to the issue of firmware has an asterisk will appear, if that firmware is NOT good, you can automatically carry out the hard disk is that it is automatically detect the hard disk, rather than self-calibration
If there is no asterisk, at select T /> enter enter N50
CTRL + Z again to enter the T /> Enter the N50, 22 carriage return, T31,, 22 carriage return CTRL + T to get started. Emergence of the need to automatically detect the hard disk for 10 minutes -20 minutes or less. Screen will appear the number of running
Of course, you can figure ranging from running, related directly to the hard drive electricity, and then in a separate power supply on, if the hard disk drive red and green point of many self-calibration may take up to 24 hours or 48 hours or longer to do a U.S. can, as long as the success of , I believe there is at the end of the U.S. psychological. Automated test and repair should not be Bad Track. Done after the necessary re-access the serial port on my N50 is the importation of some, is its self-calibration is that some, SELFSCAN is a self-healing, not to confused the
N50 finish after the end of the efficiency of the need for repair ST source software, the current Bad Track all add to the P table Generally only need to add one. To add to the overall cleared after. Bad Track and then add the rest of the G table. Bad Track if it is continuous. G do not add into the table do not control. Again in accordance with the above methods, said first automatic detection. This time to repair the hard disk. Bad Track for no
Since I tried to do with self-calibration U6 die or come to the plate 50 of the disk, is unable to complete self-calibration of the disk can also use this method to deal with
Yes, there is endless hands of U.S. self-calibration of the disk. Writing back to the firmware can use this method of test
。 Each method has the advantage of him in particular, not to count on him he is omnipotent. The attention of many methods, many try it.
T5 Also, for T31,, 22 ago, more a command T5
To see whether there is any damage to the head, and if not, you listen to the first disk, will continue to seek the
There is bad, it will then be out of the T31,, 22
Bad, it can not be
ecently, a few pieces of good repair of the Seagate hard disk of the u series. The basic fault, the disk is not recognized.
Basic method is to achieve the Directive. Here relates to some of the basic concepts of Seagate hard drives,
In fact, they do not recognize the hard disk is wrong because age parameters. Ide in the cause so do not know. , We can com line identification plate, and then at the next class T, age corrected values. Can.
Specific methods: t at the next class, type N50 (where 50 is normal. Other value of the error, you can ";" to see the value of age.) Enter, and then ^ T to. Correct, will be prompted to: the current hard drive jumper (master and slave disk) of the information.​
