notebook computer to restart, a brief analysis of crash failures and countermeasures
Restart the computer,
including notebook computers and crash failures, computer maintenance are hot issues in the process, which involves all aspects of the problem is not just a few words can be all summed up.。 I just start here, combined with the maintenance of their normal experience, do a simple analysis of these failures, if improper, but also please correct me.
The following analysis mainly 600 and T series.
Notebook computer to restart, crash failures, including a few major aspects: First, the hardware of the reasons for the basis of computer hardware, hardware compatibility and good performance is a prerequisite for stable operation of the computer, can not have good hardware, even if the system is powerless unix of.
Hardware problems laptop computers, the most headaches, because the laptop can not be as difficult or as an ordinary desktop, the system can use the smallest law, law and so on hardware replacement hardware fault location methods.
1, the resumption of power supply problems, crash failures, such as voltage instability,
Surge, etc. Underload.
Notebook computer is delicate, fragile and take a look at the power adapter and notebook computer motherboard power supply circuit can know.
Countermeasures: a, fitted with batteries,not be afraid to reduce the weight of batteries and remove the battery, especially in the power area is not so stable. After all, the battery now has a very intelligent, and unless it is some of the mentally handicapped products, otherwise there will not be any major problems.
Also should be noted that the battery should not be placed in low-temperature environment, it will affect the activity of cells.
This can be verified production cell, where the preservation of the local notebook batteries are used to achieve air-conditioning temperature around 40 degrees. So do not be afraid of our batteries have been "hot" with the.
2, not to notebook batteries and high-power electrical power received in the same seat row, especially in high-power air-conditioning appliances and so on.
This is why we all know, I do not more.
My colleagues had the power adapter for this reason giving through.
3, interface relaxation, there are two, one CPU socket loosening and death caused by the resumption of failure, such a situation, during maintenance work is particularly common.
Welding in the kind of CPU on the motherboard rare books.
If there is a particularly good book or the resumption of death, and this book and it fell from a height or a serious collision had been, we can give priority to the case of loose slots.
Measures to re-plug, if necessary, repair Broken Needle.
Second, the hard disk, optical disk drive interface, such as loosening.
I have come into contact with a laptop computer, usually a small program to run no major problems, but once the operation of large-scale program such as photoshop will crash when no doubt, by the detection of local damage to the hard disk interface.
Interface is the replacement of countermeasures, if necessary, replace the motherboard, optical drive interface, hard disk interface and so on.
4, the quality of non-performing hardware, such as poor memory is often the manufacturer is often blue screen.
Responses: high-quality replacement parts, whether or not the original there is no need to ask the.
Second, the software fault
1, the uncertainty of the operating system itself, such as win98, win98se instability are obvious to all, win2000, winXP, linux, etc. on the stability of the operating system much better.
Countermeasures: In terms of hardware, subject to conditions, upgrade the operating system, for example, 600,600 E to the operating system upgrade to win2000.
2, the virus, which goes without saying.
Genuine solution is to buy anti-virus software, the most critical is escalating, Internet before, it is best to upgrade anti-virus software first.
Rarely or never upgrade the antivirus software upgrade and deaf ears is not differentiated.
3, directx and death caused by failure to restart.
Countermeasures: A, re-install or update driver
B, the abolition of directx test equipment.
4, the conflict between software countermeasures: A, as far as possible avoid the use of test software,
B, delete the software easy to cause problems,
C, the installation of system optimization software, such as optimization of the master and so on.
Fourth, non-performing heat-induced death, failure to restart the books now increasingly smaller, more and more books within a narrow space, and the CPU, hard disk, memory, etc. are more and more heat, although the notebook's CPU , hard disk, etc. is still relatively strong, but they are still in the heat alone will not help before, especially the poor design of the notebook is a good fat such persons, such as some Chinese-made books, such as the T20 on the thermal design not particularly good, the problems in the T series is also more severe.
In addition there are bad heat problem caused by a series of chains, such as accelerated aging components and so on.
Strategies: Do not block the cooling holes, not to let the books and blankets and other soft objects such as close contact to do, use the water pillow and so on.
Fifth, other reasons, such as cola killer killer air-conditioning, the environment, such as killer
الكاتب
1 يونيو 2009
رد: notebook computer to restart, a brief analysis of crash failures and countermeasu
بارك الله فيك
