  • بادئ الموضوع NOOOOR
  • الردود 15
  • المشاهدات 14K
HDD Low Level Format Tool
License: Freeware
Author: HDDGURU.COM
Operating System: MS Windows 2000SP4/2003/XP
HDD Low Level Format Tool is a freeware utility for low-level hard disk drive formatting.
* Supported interfaces: S-ATA (SATA), IDE (E-IDE), SCSI, USB, FIREWIRE. Big drives (LBA-48) are supported.
* Supported Manufacturers: Maxtor, Hitachi, Seagate, Samsung, Toshiba, Fujitsu, IBM, Quantum, Western Digital.
* The program also supports low-level formatting of FLASH cards using a card-reader.
This freeware Low Level Format utility will erase, Low-Level Format and re-certify a SATA, IDE or SCSI hard disk drive with any size of up to 281 474 976 710 655 bytes. Will work with USB and FIREWIRE external drive enclosures. Low-level formatting of Flash Cards is supported too. Low Level Format Tool will clear partitions, MBR, and every bit of user data. The data cannot be recovered after using this utility. The program utilizes Ultra-DMA transfers when possible.
WARNING: After running this free low level format tool, the whole disk surface will be fully erased.
Therefore, data restoration will be impossible after using this utility!
للتحميل من هنا
http://hddguru.com/download/software/HDDGURU-Low-Level-Format-Tool/LLFsetup.2.36.1181.exe​
en.mohamedsaid
شركة عيون دمياط
24 فبراير 2009
جزاك الله خيرا بشمهندس محمد
aymantaraf
28 مارس 2009
مشكور على البرنامج
format hdd low level tool
