أدوات تغير الهدود SD Head Replacement Toolkit
متوفر لدينا بفضل الله تعالى ادوات فك الميديا ونقل الهدود
attachment.php
attachment.php
الجزء الاعلى بالصورة وهى تولز تساعد على تركيب الهيد بالميديا
Read Write Head Replacement Tools :
This article explains about read write heads and how crucial it is to keep the heads from crashing which is why we developed the read write head tool to remove the heads safely.
To keep the heads from crashing into the platter is just as important to keep them from crashing into each other although they shouldn't be allowed to touch the platters. HDDWORLD has developed a tool that when used in a data recovery process will prevent the read / write heads from making contact with each other, and /or crashing to the platter.
The heads on each type of drive sit at different heights to fly over the different heights of the platters. The platters vary in height due to the spacers that are used to keep them apart. HDDWORLD read write head tool is fully adjustable for one or more heads at different heights. One tool fits all. This can do multi platter, single platter and dual or two platter hard drives head stack swaps.
The tool itself is very simple to use and causes no damage to the heads or the platters surface.
The tools are available for both desktop and laptop hard drives to work both you would need both of the products (These are included free in our online courses). Once you have adjusted them to the appropriate heights using the platters as a guide you simply slide the heads onto the wedges to remove the heads without damage.
If we were to take a close look at a read / write head we would see that there are copper coils belonging to the transducer, and tiny electric wires attached to gold pads.
  • SD-Head-Replacement-Toolkit-User-Instructions.rar
    197.9 KB · المشاهدات: 291
  • SD-HRT-Packing-List.rar
    58.2 KB · المشاهدات: 145
  • Support-List-of-SD-Head-Replacement-Toolkit.rar
    200.6 KB · المشاهدات: 187
    58.8 KB · المشاهدات: 764
    40.3 KB · المشاهدات: 788
gald2011
26 أكتوبر 2011
رد: أدوات تغير الهدود SD Head Replacement Toolkit
السلام عليكم ممكن الاسعار لو سمحت وسعر سليفيجن الخاص بالهارد الهاتاشي والماكستور شكرا
belal-pc
16 يونيو 2010
مشكور بس ممكن سعر عل ايميل belal-pc@hotmail.com
للاستفسار عن السعر الاتصال بالموبايل موجود في التوقيع
mn_s_55
15 فبراير 2012
ممكن السعر يا بشمهندس برساله علي الخاص
